Abit of help
Ok so did a search but didn't really find what I was looking for, question is am I going to struggle to get alloys of 17x7 ET45 PCD 5x112 to fit, as I've read that adapters/spacers start at 15mm where as I would need 10mm to get the offset to 35. Am I right In thinking this is true, if so is there anywhere I could get the 10mm's from or even custom made possibly?
The reason they'll start at 15mm is because your screwing into them. . With 10mm you'll only have 10mm of the bolt end screwed in. .which i imagine won't be very safe.
They don't have to be et35. . .with 15mm adapters it'd only be et30. . Which i think you,d get away with,it depends how you want the wheels to sit in the arches. . .
I've run et25 up front and et15 on the back last year.
Edited by vrs'burks
