XDS - software only or hardware required?
I have just activated buttonless TPMS - Controller 03 > Byte 16 > Bit 2 and Controller 17 > Byte 2 > Bit 0 and while in the controller observed a bit for XDS installed yes/no. I ticked yes and the coding was accepted and no error codes present after going for a drive. I was able to set the level in adaptations too. Is it possible that it is actually built in to the later cars but not activated?
Yes, yet some do not have all necessary hardware required - if in doubt post an Auto-Scan and we'll check...
It does seem to be working but here is the scan, thanks.
Tuesday,08,January,2013,19:38:28:18620
VCDS Version: Release 11.11.5 (x64)
Data version: 20121222
Chassis Type: 7N0
Scan: 01 02 03 08 09 10 15 16 17 19 25 42 44 46 52 56 62 72
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine (CDA) Labels: 06J-907-115-CDA.clb
Part No SW: 3T0 907 115 G HW: 1Z0 907 115 F
Component: 1.8l R4/4V TFSI 0030
Revision: AAH18--- Serial number:
Coding: 0203000C24070160
Shop #: WSC 73430 790 00095
VCID: 3561E6BB5C09CAB0C2A
No fault code found.
Readiness: 0000 0000
Address 02: Auto Trans Labels: 0AM-300-04x.lbl
Part No SW: 0AM 300 053 A HW: 0AM 927 769 D
Component: GSG DSG AG7 431 3010
Revision: 00043014 Serial number: CU501203136499
Coding: 0000020
VCID: 2A5BC5C785B795485F8
Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 BJ HW: 1K0 907 379 BJ
Component: ESP MK60EC1 H31 0121
Revision: 00H31001
Coding: 133B401C09290003C81402ED90190081350800
VCID: 7BF53083FAADDCC074E
Address 08: Auto HVAC (J255) Labels: 5K0-907-044.clb
Part No SW: 3T0 907 044 BK HW: 3T0 907 044 BK
Component: Climatronic H18 0506
Revision: 00001007
Coding: 0000000002
ASAM Dataset: EV_Climatronic A01010
ROD: EV_Climatronic_SK35.rod
VCID: 7CF7339FF7A3DBF87D4
Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
Part No SW: 1K0 937 087 Q HW: 1K0 937 087 Q
Component: BCM PQ35 H 110 0651
Revision: 00110 AC
Coding: 46000AB8E05BB1C040100080110081E0477800AE726D89605C8040000040
Shop #: WSC 17015 576 92329
VCID: 3F8D8493AE3500E0186
Subsystem 1 - Part No: 1Z2 955 119 D Labels: 1KX-955-119.CLB
Component: Wischer 25031 26 0601
Coding: 00DFB7
Subsystem 2 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 030412 05 54 0403
Coding: 0730ED
Subsystem 3 - Part No: 1Z0 951 171
Component: Innenraumuebe 008 5101
Subsystem 4 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
Address 10: Park/Steer Assist (J446) Labels: 5J0-919-475.clb
Part No SW: 5J0 919 475 A HW: 5J0 919 475 A
Component: PARKHILFE 4K H11 0005
Revision: --H11--- Serial number: 32961209100966
Coding: 10810E
Shop #: WSC 13765 790 00095
ASAM Dataset: EV_EPHVA14SKxxx0000 001001
ROD: EV_EPHVA14SKxxx0000_SK35.rod
VCID: 3365D8A39A7DD480ECE
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 T HW: 1K0 909 605 T
Component: Q4 AIRBAG VW8 020 2300
Revision: 05020000 Serial number: 0038PD2VZV1K
Coding: 0020788
VCID: 3D71FE9B643912F00AA
Address 16: Steering wheel (J527) Labels: 5K0-953-569.clb
Part No SW: 5K0 953 521 AQ HW: 5K0 953 569
Component: LENKS.MODUL 014 0140
Revision: FF010040 Serial number: 20120404801259
Coding: 5880140000
ASAM Dataset: EV_SMLSNGVOLWSXS A01004
ROD: EV_SMLSNGVOLWSXS_SK35.rod
VCID: 7BF53083F2ADDCC074E
Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
Part No SW: 1Z0 920 903 Q HW: 1Z0 920 903 Q
Component: KOMBI H06 0608
Serial number: 00000000000000
Coding: 410E01
Shop #: WSC 73430 031 00095
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04114
ROD: EV_Kombi_UDS_VDD_RM09_SK35.rod
VCID: 43858863CADD64007CE
Address 19: CAN Gateway (J533) Labels: 7N0-907-530-V2.clb
Part No SW: 7N0 907 530 M HW: 1K0 907 951
Component: J533 Gateway H42 1623
Revision: H42 Serial number: 260312F2001085
Coding: 351303
VCID: 3A7BF587B51725C82F8
Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H06 0608
Coding: 000000
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03009
ROD: EV_Immo_UDS_VDD_RM09_SK35.rod
VCID: EADB85C70D37D5481F8
Address 42: Door Elect, Driver Labels: 1K0-959-701-MAX3.lbl
Part No SW: 1T0 959 701 AA HW: 1T0 959 701 AA
Component: Tuer-SG 009 2120
Coding: 0004854
Shop #: WSC 73430 790 00090
VCID: 76E321B7018F81A80B0
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K0 909 144 P
Component: EPS_ZFLS Kl. 69 3305
Revision: 00H22000
VCID: 377DECB3460538A0D06
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX3.lbl
Part No SW: 1T0 959 702 S HW: 1T0 959 702 S
Coding: 0004854
VCID: 489F9F4F3BFB4758A9C
Address 56: Radio (J503) Labels: 5M0-035-1xx-56.clb
Part No SW: 1Z0 035 156 F HW: 1Z0 035 156 F
Component: BOLERO 010 0061
Revision: 0A001001 Serial number: SKZ1Z3M0102256
Coding: 0D0004000001
VCID: 3561E6BB9C09CAB0C2A
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
Part No SW: 5K0 959 703 A HW: 5K0 959 703 A
Component: Tuer-SG 007 2101
Coding: 0000144
Shop #: WSC 73430 790 1012575
VCID: 326BDDA7AD67DD88E78
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
Part No SW: 5K0 959 704 A HW: 5K0 959 704 A
Coding: 0000144
VCID: 3365D8A3527DD480ECE
End ---------------------------------------------------------------------
Yep, should work just fune.
