Hoping someone with a bit more knowledge than me could shed some light on the faults below please. Thanks
Wednesday,09,January,2013,20:51:38:30196
VCDS Version: Release 11.11.5
Data version: 20121222
Chassis Type: 7N0
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72 76
VIN: TMBGS21Z882022989 Mileage: 91750km/57010miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: OK 0000
Address 01: Engine Labels: 03G-906-016-BKC.lbl
Part No SW: 03G 906 021 LB HW: 03G 906 021 AN
Component: R4 1,9L EDC G000SG 9251
Revision: --H07--- Serial number: SKZ7Z0G4301152
Coding: 0000071
Shop #: WSC 66565 257 00032
VCID: 6AD1E999450A1D489F8
1 Fault Found:
005659 - Glowplug for Cylinder 2 (Q11)
P161B - 000 - Open Circuit
Freeze Frame:
Fault Status: 01110000
Fault Priority: 0
Fault Frequency: 1
Mileage: 87043 km
Time Indication: 0
Date: 2000.00.00
Time: 17:33:14
Freeze Frame:
RPM: 882 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.29 V
Bin. Bits: 00101100
Temperature: 12.6°C
Bin. Bits: 10110000
Readiness: 0 0 0 0 0
Address 09: Cent. Elect. Labels: 3C0-937-049-30-H.lbl
Part No SW: 3C0 937 049 AJ HW: 3C0 937 049 AJ
Component: Bordnetz-SG H54 2202
Revision: 00H54000 Serial number: 00000004996601
Coding: C18A1B111014140000110D000000000000097F075C000000000000000000
Shop #: WSC 12345 123 12345
VCID: 71E3FEF568DCEE90DE2
Subsystem 1 - Part No: 1Z2 955 119 C Labels: 1KX-955-119.CLB
Component: Wischer 060607 022 0601
Coding: 00057271
Shop #: WSC 12345
Subsystem 2 - Part No: 1K0 955 559 AF Labels: 1K0-955-559-AF.CLB
Component: RLS 180607 046 0204
Coding: 00471077
Shop #: WSC 12345
1 Fault Found:
02390 - Control / Regulation for Ambience Lighting (E400)
009 - Open or Short to Ground
Freeze Frame:
Fault Status: 01101001
Fault Priority: 5
Fault Frequency: 1
Reset counter: 13
Mileage: 91466 km
Time Indication: 0
Date: 2005.09.13
Time: 31:63:63
Freeze Frame:
ON
Voltage: 12.40 V
ON
ON
OFF
OFF
OFF
Address 19: CAN Gateway (J533) Labels: 7N0-907-530-V2.clb
Part No SW: 7N0 907 530 C HW: 1K0 907 951
Component: J533 Gateway H37 0614
Revision: H37 Serial number: 250511F1000766
Coding: 352303
Shop #: WSC 00152 210 91233
VCID: 30653BF16356A79891C
1 Fault Found:
01305 - Databus for Infotainment
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 1
Fault Frequency: 2
Reset counter: 40
Mileage: 91269 km
Time Indication: 0
Date: 2000.00.00
Time: 00:00:02
Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT
Component: KSG PQ35 G2 020 0204
Revision: 00020000 Serial number: 00000000000000
Coding: 98801A085283007F3F04850540085F96907CA0
VCID: 830F243DC2606C00BCE
Subsystem 5 - Part No: 1Z0 951 171
Component: Innenraumueberw.008 4801
Coding: 00000000
Shop #: WSC 12345
Part No: 1K0 951 605 D
Component: LIN BACKUP HORN H07 9001
Component: NGS n.mounted
1 Fault Found:
01135 - Interior Monitoring Sensors
Freeze Frame:
Fault Priority: 4
Fault Frequency: 2
Reset counter: 214
Time Indication: 0
Address 56: Radio (J503) Labels: 5M0-035-1xx-56.clb
Part No SW: 1Z0 035 156 M HW: 1Z0 035 156 M
Component: BOLERO 001 0008
Revision: -----08S Serial number: SKZ4Z3M1151686
Coding: 0D0004010001
VCID: 3C7D1FC1BF1E53F83D4
9 Faults Found:
00849 - S-contact at Ignition/Starter Switch (D)
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 40
Mileage: 0 km
Time Indication: 0
00871 - Bass Speaker Front Right (R23)
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 187
Mileage: 0 km
Time Indication: 0
00872 - Bass Speaker Rear Left (R15)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 187
Mileage: 0 km
Time Indication: 0
00873 - Bass Speaker Rear Right (R17)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 187
Mileage: 0 km
Time Indication: 0
00856 - Radio Antenna
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 2
Reset counter: 0
Mileage: 0 km
Time Indication: 0
00821 - Antenna 2 for Radio (R93)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 3
Reset counter: 46
Mileage: 0 km
Time Indication: 0
Freeze Frame:
Fault Priority: 6
Fault Frequency: 3
Reset counter: 187
Mileage: 1048575 km
Time Indication: 0
01317 - Control Module in Instrument Cluster (J285)
Freeze Frame:
Fault Status: 01100100
Fault Priority: 6
Fault Frequency: 1
Reset counter: 0
Mileage: 0 km
Time Indication: 0
Date: 2000.00.00
Time: 22:05:17
01327 - Control Module for Parking Aid (J446)
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 0
Mileage: 0 km
Time Indication: 0
Date: 2000.00.00
Time: 22:05:17
End ---------------------------------------------------------------------
Clear them and see if any reappear.
Have you taken the radio out recently?
Yea, changed it from stream mp3 to bolero
Most of those errors are from the radio swap. Like I said, clear them and see if any come back.
Might also be worth thinking about changing the glow plugs seeing as the car has done nearly 60K. If the glow plug fault comes back it would be worth checking the wiring and plugs to the glow plugs.
Thanks, will clear them and check again in a week. How often should glow plugs changed please?
When they don't work very well!
I changed the glow plugs in my old octavia after 50-60k, but from what I've seen the PD engines need the glow plugs less than the injection pump diesels, not sure about the CR engines though.
If you have any problems starting when it is cold and double cycling the ignition helps then I would change the plugs.
I would clear the codes, start the car, turn it off and then scan again, anything which is constantly faulting will show up straight away. Then leave it a week and try again.
Thanks for your help. I did a search and it said if it fails to start then they need changing. Touch wood it starts brilliantly and our mechanic said it was a really nice car. Makes up for the Fabia vrs we bought that wasn't so great :(
Even if the glow plugs are completely rubber ducked it will start (eventually) although you may disappear in a cloud of smoke in the process.
Shall see what happens when I clear the fault. It was just serviced and nothing was mentioned but always good to keep an eye out. Handy having a wife that works at a good independent :)
