HELP!
Right, i've had no heat coming through blower for a while, so i got advised to flush coolant and jetwash into the heater matrix by disconnecting the hoses just to the right of the airbox, so i do this and i get heat through, thank god.. then coolant problems start to arise because the metal pipes at the back of the engine that go into the inside of the car to the heater matrix have corroded and unfortunately snapped off when i put my hand down the back of them, now do i need a new heater matrix or can i buy the metal pipes alone? help would be appreciated and if anyone else has had this problem with heat or coolant let me know.. :think: Problems after problems..
also just looked again and there is an allen key that looks like it holds the metal pipes in? maybe?
