Help
I need some help on the following please:
1) I posted earlier about removing the underseat storage compartment under passenger seat it has only got one screw which I have removed but it still wont shift and I would rather not just yank it
2) Secondly I need another cigarette lighter for power in the vehicle (already have the bits for it came out of my astra) problem is the car is too well built I can not find a way into the car from the engine compartment. I know some of you have powered amps from the battery how did you get the leads through. Where is the pollen filter what does it look like and i will try and find the grommit there.
I need to sort these problems by Tuesday morning for work.
Oh for a haynes manual that shows things
I ran the cable for my amp through a grommit in the bulk head that is just under the tray that the washer jets sit on, on the passenger side. A nice wire coat hanger and a torx bit for removing the glove box will help! There is a guide on here somewhere... :)
Matt
Thats a good ad for the car :thumbup:, altho does that mean your astra wasn't ? :)
The seat have can out to remove the two back screws on the box
Okay an update got the cable through :thumbup: no skin left on knuckles though.
There only appears to be one screw on the passenger storage box undone that on but can not find any more not noticeble.
And Steve you are right the sound proofing on my all be it petrol astra was none existant and I was screaming blue murder about the build quality yesterday all I wanted was a slight gap!!!!
I've fitted a four way extension lead bought from Halfords - fixes via adhesive pads underneath the heater controls - then lead runs down alongside drivers seat to plug into existing socket. The plug also has a pushbutton on/off switch on the top.
Currently powering RA2 + mobile phone - with spares for tyre compressor (though I usually unplug the adaptor and use the original socket for convenience), rechargable torch and possible satnav.
