Fault code reader advice
Hey guys, just bought a fault code reader off ebay which should be here in the next couple of days.. Just wondering, as ive neeeever done anything like this before haha, where do i plug it in? Vs450 model bought from ebay for around £28 by the way :)
Cheers!
You plug it in the obd port, to the right of the steering wheel and down a bit.
Ah right, what do i have to remove to get to it mate? I thought it was there... will be using it quite frequently cause ive just downloaded the torque app and bought a bluetooth obd2 adaptor :)
Open the cubby hole, and then press the locating tab at the top so the door drops down and you will see the plug.
I guess you mean the cubby hole with the on off button thing at the top, if so, great cheers mate :)
That's the one!
SN
Cheers guys, found it :)
Yeah when scanning have keys out of ignition. Plug unit into obd port...
Then turn ignition on.
Do not start car
Then your good to go!
The unit gives a good explanation
Ah great, thanks for the explanation :)
For example...
Faults on my bro's car
Even better haha! Many thanks mate
