fuel issue?/?
hi can some 1 help please.. i was driving home from work on wedensday and my car jusddered all of a sudden then just died.. it turned over fine but just would not fire up.. fule was getting to all the injectors and the pump seems to be working fine.. the next day i changed the fule filter and tryed to start the car after 5 turns it started .... i turned it back of and on a few time and it started fine every time so i left it ticking over for 5 mins and it just cut out and now i have the same problem again iut wont start.. i have taken the float out the tank and cleaned the gause as it has a l.ittle sludge on it.. when the caw was running after i changed the filter the glow plug light was flashing on and off on the dash this never used to happen.. also the wiper fuse keeps blowing not sure if this has any thing to do with the problem .. any help would be much appreciated as i am stumped..
Have you had the codes read/do you have VCDS/Vagcom?
If not, I notice you're in Durham, so I could probably help out with that.
no i have not bud.. i carnt get it towed to a garage every 1 is busy or working..
So where's the car at the moment?
its at my house in roddymoor near crook are you mobile? how much do u charge
I don't charge, I don't do this to make money, spannering's a hobby for me - I'm just a very well equipped hobbyist :)
Sadly Crook's a little out of the way for me at present though, I was hoping you might be nearer to Durham. I could probably get over some time next week but that's probably not much help to you is it?
it could be bud i like to fix things my self rather than use garages .. i will use my motor bike to get to work untill the car is fixed .. i will keep u posted and let u no if i get it sorted .. thanks for the help
No bother. Drop me a PM if I can help out.
