Can MFSW be fitted to a manual VRS?
Hi,
Can you fir the MFSW with paddles to a manual VRS (Blackline) and use the buttons for radio, phone etx just leaving the paddles?
Yes, you can either then remove the paddles and blank the holes off if required or buy a MFSW without the paddles.
Yes you can
I have one retro fitted to my manual Diesel vRS
Do a search as there are a couple of threads that describe exactly the parts that are needed along with a copy of my coding that will make this work.
Gizmo68 above is an expert at this :D
Tried shark performance today but they said they no longer offer the service as it is too complex. Anyone know anyone in the north (Yorkshire and surrounding) who still does this and does a good job. It's to fit my blackline
I added one to my Vrs
Who did it and was it expensive? I do lots of motorway miles and prefer to keep my hands on the wheel!
You could try OEMretrofits: www.oemretrofits.co.uk/ They may be able to help. I had mine done by Shark performance; I sourced all the bits from Skodateile (may not quite have spelling correct) and Shark installed. It's a pity they don't still do them.
Sarge.
You can retrofit a mfsw without paddles. I've retrofitted one to my 1.8 tsi manual. Check skodateile I think he has them in stock.
& if you do fit a one with paddles, as far as I know i dont think you can code the paddles to do something else like change channels or whatever.
No such options available on vcdd
I've got one ready to go on - as above its from skodateile.cz - should be on later this week all being well. Ales @ skodateile is very helpful, great service.
