Question from a car tweaking newbie (repost from incorrect forum section)
Hi folks
Sorry if this come across as alittle "chavy" im not honest, i just thought i would give the vrs alittle bit more ooomph
Ive decided to give my octavia alittle "tweak" so soon ill be looking for somewhere to do a remap as im under the impression it makes alot of difference to the power delivery? (new to this)
Now to the chavy bit? im considering a forge blow off valve, but as my experience is of the 2 wheel variety (most of which dont have turbo's and none ive ever seen with a bov) i have little real world knowledge of these. I know how they work (equalising the pressure in front and behind the turbo effectively allowing it to free wheel when the throttle is closed), what im worried about is potential problems if any this will cause? so if you have done it i would apprieciate any feed back you can give.
A long time friend and impreza adict swears by them, and he atleast has had no side efects.
Oh and i do like the sound... i know its generally associated with a 1.2 nissan micra with a 12 inch exhaust lol... but so are 18 inch alloys... and im not avoiding them either :D
A set of turbo hoses are already on there way, and i might go for some kind of induction upgrade at some point.
Thank you
Cars 2007 petrol vrs, and im near southampton.
Edited by Craigt191
Mine got a forge spit r dump valve and Never had problem with it
O and yep a good map makes a lot better
Thank you. Ill go shopping for somebody to remap it then.
I wouldn't recommend any valve that expels your boost to the atmosphere, particularly since that's not how your VRS was designed to operate. You have a closed system, in which the excess boost pressure is meant to be recirculated into the induction system.
With a closed, MAF-based system (2.0T FSI for example), your car expects X amount of air to be in the system at all times to achieve optimal air/fuel ratio with Y amount of fuel being injected into the combustion chamber. If you allow some of this air to vent into the atmosphere--effectively decreasing X--you have just created chaos for your car/ECU's air/fuel calculations. Your ECU, expecting more air to be in the system, must now register the decrease in X and recalculate how much Y it needs. Adjusting for less air in the system, it will decrease fuel and your car will run lean for a short period of time. With a BOV or atmospheric DV spacer, etc., your car is constantly battling to achieve the desired air/fuel ratio.
During normal driving (off boost), turbocharged motors live in vacuum; potentially enough vacuum to hold the BOV/DV open. If the BOV is open, during regular driving, that's extra, unmetered, unfiltered air entering your system.
Instead of picking up a BOV or DV spacer or their equivalent for the ricey "woosh" makes you weak in the knees watching The Fast and the Furious; opt for a Rev D, OEM diverter valve (cheap!) and a good induction kit to open up that intake a bit more and give you more induction noise you're looking for. ;)
I'd go for a remap and induction kit as my first modifications. Here are details of what we offer:
http://www.goapr.co....tfsi_trans.html <Remap
http://www.goapr.co...._fsi_trans.html <Induction kit
Hope this information helps!
