monte tailpipe ?
just to finish off my monte s back end i have trawled the net looking for a tail pipe that would just set it off any body out there got one or do you have to get a complete exhaust i dont mind cutting the black trim diffuser thanks
If you go for a trim you will to cut the tail pipe.
Now i went to this and having second thoughts.
As if you cut the splitter and bumper it leaves a hole for dirt and **** to go up in side your bumper.
Skoda recomend fitting a another splitter, i can only asume thenew splitter has a bit of trim the covers the hole you will make.
hi well i managed to find a tailpipe on the web no need to cut the splitter thing ordered the 4th came today the 6th fitted tonight looks well unable to put pictures on site says you have exceeded alloted disk space for attachments #rap with computers cant put pictures on but web site is www.passionauto.co.ukthe item i have got is a E TECH drop down £17 slight modification reqd with grinder to make unit sit level but first class job if i can will try some pictures sometime
Edited by ken b
Ive seen pipes that come out that low not a fan tbh
its what I've done with mine! fitted a drop down chrome trim onthe existing tailpipe. It exits directly under the diffuser and looks Ok. I'll try to shows pics.
Pics anyone ???
