Superb 1 2.8 2006, Central Electr. and Fuel Pump Ctrl module
Hi all,
I have a 2006 2.8 Superb Elegance here in Dubai, Middle East spec. Just got my Ross-Tech VCDS, and as expected a lot of fault codes stored in memory. Cleared all, but a few remain. But first of all, am unable to access group 09, central electronics. Does the 06 model have this module? (Built 10/05) What functions are controlled by this? Am a bit surprised I can not see the fuel pressure while running through the blocks with engine running. I have a misfire at about 1300 rpm and again at 1700 rpm. Severity varies, at times it is smooth as silk. No fault codes showing after several days and about 500 km varied driving. Leaking injector?
I'd be gratefull for some answers, and if anyone in Dubai needs a quick scan, feel free to pm me.
Little bit too quick there, also got 00476, Control module for fuel pump, (J 538) Any connection with central electronics?
Welcome,
The MKI Superb does not use channel 09, it uses channel 46 Central Conv. instead.
I will add you on the VCDS owners map & list.
Thank you for the reply. Any idea about the fuel pump? Don't seem to have any problem except the misfire, it says 49-00, No communication. Any idea where the control module is?
Im sure I have read that the only vehicle fitted with the J538 module is the W8, post a full scan up as there maybe something coded wrong.
Hi Gizmo, this is what my scan looks like:
Friday,08,February,2013,14:45:21:07851
VCDS Version: Release 11.11.5 (x64)
Data version: 20121222
Chassis Type: 3U - Skoda Superb I
Scan: 01 02 03 08 15 16 17 19 36 37 46 47 55 56 76
VIN: TMBBT23U469107972 Mileage: 161570km/100394miles
Address 01: Engine Labels: None
Part No: 3B0 907 551 CJ
Component: 2.8L V6/5V G01 0050
Coding: 26551
Shop #: WSC 00028
VCID: 6DD11A4E278F5570FAA
TMBBT23U469107972 SKZ7Z0E3220844
No fault code found.
Readiness: 0110 1101
Address 02: Auto Trans Labels: 01V-927-156.lbl
Part No: 8D0 927 156 DJ
Component: AG5 01V 2.8l5V RdW 1111
Coding: 00103
Shop #: WSC 00028
VCID: 78FF3B1A58CDE0D819C
Address 03: ABS Brakes Labels: 3U0-614-517.lbl
Part No: 3U0 614 517 D
Component: ABS/ESP front 1314
Coding: 04497
Shop #: WSC 00028
VCID: 3467CF2A0425C4B8F54
Address 08: Auto HVAC Labels: 3U0-907-044.lbl
Part No: 3U0 907 044 A
Component: CLIMATRONIC S B5 C 2004
Coding: 17000
Shop #: WSC 00028
VCID: 3169C63EFB37F1909E2
1 Fault Found:
01274 - Air Flow Flap Positioning Motor (V71)
37-00 - Faulty
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 1C0 909 605 K
Component: 03 AIRBAG VW51 0K 0008
Coding: 12339
Shop #: WSC 00028
VCID: 2C57D74ADC159C78AD4
Address 16: Steering wheel Labels: 1J0-907-487-A.lbl
Part No: 1J0 907 487 C
Component: Lenkradelektronik 0006
Coding: 00118
Shop #: WSC 00028
Address 17: Instruments Labels: 3U0-920-xxx-17.lbl
Part No: 3U0 920 841 C
Component: KOMBI+WEGFAHRSP VDO V06
Coding: 31125
Shop #: WSC 00000
VCID: 3365CC36012BC380ECE
2 Faults Found:
01336 - Data Bus for Comfort System
49-10 - No Communications - Intermittent
00476 - Control Module for Fuel Pump (J538)
49-00 - No Communications
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 00028
VCID: F0EF833AB0BD389851C
2 Faults Found:
Address 36: Seat Mem. Drvr Labels: 3B1-959-760.lbl
Part No: 3B1 959 760 E
Component: ?301
Shop #: WSC 00000 065 00000
VCID: 2F6DC046BD03E760886
Address 37: Navigation Labels: 3B0-919-887.lbl
Part No: 1U0 919 887 B
Component: Navigation BNO 0102
Coding: 00002
Shop #: WSC 00028
VCID: 428B99F24E917A08778
Address 46: Central Conv. Labels: 1C0-959-799.lbl
Part No: 1C0 959 799 B
Component: BB Komfortger?t HLO 0004
Coding: 00258
Shop #: WSC 00028
VCID: 3663F5221259D6A8CB0
Subsystem 1 - Part No: 1C0959801
Component: BB T?rsteuer.FS KLO 0202
Subsystem 2 - Part No: 1C0959802A
Component: BB T?rsteuer.BF KLO 0202
Subsystem 3 - Part No: 3U0959811
Component: BB T?rsteuer.HL KLO 0202
Subsystem 4 - Part No: 3U0959812
Component: BB T?rsteuer.HR KLO 0202
Address 47: Sound System Labels: 1J0-035-456.lbl
Part No: 3U0 035 456 B
Component: Soundprozessor 3 0002
Coding: 00571
Shop #: WSC 00028
Address 55: Xenon Range Labels: 4Z7-907-357.lbl
Part No: 4Z7 907 357
Component: dynamische LWR D09
Coding: 00005
Shop #: WSC 73430
VCID: 04075FEA1405B438054
Address 56: Radio Labels: 3B0-035-186.lbl
Part No: 3B0 035 186 D
Component: Radio BNO 0102
Coding: 00027
Shop #: WSC 00028
VCID: 204F337AA0DD481801C
Address 76: Park Assist Labels: 3U0-919-283-7X1.lbl
Part No: 3U0 919 283 A
Component: Einparkhilfe V002
Coding: 01114
Shop #: WSC 00028
VCID: 3979FE1E234739D0262
End ---------------------------------------------------------------------
Removed drivers seat today and checked CCM, clean as new. Cleaned all connectors and ground connections, removed all connectors behind the kick plate and cleaned with Lectra-clean. As you can see the fault is still there. Anywhere else to check? Everything is working as it should, might there be a bad connection between the diagnostics plug and the system?
Another thing, am I not supposed to see the fuel-pressure while going through the measuring blocks?
I don't see any mention of electric mirrors, puddle lights or solar sunroof in channel 46 either.
