what clocks will fit?
is there any speedo clocks that will fit inn a fabia ie mk4 golf etc as they look pretty much the same
You could probably use the plastic bezel/ sheet from an Ibiza, polo etc if they use a similar shape. That would save you having to reprogrammed the immobiliser :)
