Help! Twindoor stopped working
Hi folks,
I decided to vacuum the Superb out this afternoon and found that the twindoor will open in bootlid mode only with only the remote key, no boot or hatch mode from the car as both of the buttons on the twin door have stopped working.
1st I checked the fuse (ok) then plugged in VCDS and got the following fault log;
03396 - Supply voltage terminal 30 for central locking
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 1
Fault Frequency: 1
Reset counter: 147
Mileage: 167209 km
Time Indication: 0
Freeze Frame:
Term 15 Off
Voltage: 12.25 V
OFF
ON
Term 50 Off
OFF
OFF
Before I go scouring the online manual for help can anyone give me any guidance?
Many thanks
Mart
Does this help? Start at the top!
http://www.briskoda...._1#entry2499407
It helped me.
Stuart
Thanks Stuart,
I had seen this earlier and I'm going to try it tomorrow although the fauld code points in another direction, I think?
Dunno! A faulty sensor could leave an open circuit? It seems that the mechanical issue in that thread can manifest itself for no logical reason, the tolerances between working and not beng so close.
I just wish skoda would dispence with the electical boot and hatch opening and just fit a manual handle
agreed
Terminal 30 sounds like the power supply terminal into a relay that controls the system, does the handbook show one that controls the twindoor on the Superb?
Ian
Ian
I've been on Erwin and printed all the relevant material from the workshop manual but haven't had time to work on it yet, I'll report progress as and when I get around to it for anyone else's benefit.
I had same problem, turns out the wires had been broken on the loom which run inside the twindoor! they run inside on the left hand side and require removal of the plastic trim, garage spliced the wires and all worked well again.
Finally got around to fixing this, problem was as above. The wires from the bootlid switches run through the left hand bootlid hinge and up the left side of the window, if you open and close a lot in boot mode rather than full hatch the wiring gets open and closed around the hinge eventually breaking. Took me about 5 hours to fix, I've got pics if anyone's interested.
Even in nobody is interested now, it might well be useful to someone in the future if you could post a DIY guide and photos for the fix. Did you find the Elsawin info useful?
I will put a guide together with pics ASAP, yes the elaswin was useful if less than crystal clear in places.
Any update on posting the pics and guidance?
Looks like I got the same problem today; neither of the trunk buttons do anything, and with remote I can only open the smaller lid. Would be nice to get some hints before I will start opening (breaking...) things.
  • 1 year later...
Here: http://www.briskoda.net/forums/topic/286139-superb-twindoor-wiring-fix/
I had this on the rear door of my Omega, the micro wires simply don't take the brunt of what is effectively the same as a wiggle break during the opening and closing, that and clod hoof who boots it as they go to get out and the rubber cover takes a full on hit.
