Pre cat removal on vrs
Anyone removed the innards and refitted? Any lights on, thinking it as a cheap mod as decats and sports cats downpipe are so expensive :(, this way I can remove a bit of restriction and keep the Oem cat
have you looked into pipewerx downpipe & decat?
I have this setup on my TFSI Golf ;)
Ant
Don't worry guys found all I need cheers, as for the pipeworx it's still more then I want to pay at the min
I have had the precat removed and went to stage 2, pushing 290-ish on 98 fuel.
The stage 2 also removes any alarm bells that you might get.
I done mine mate.
Removed the precat & drilled out the dodgy inside material.
No alarm bells & more mpg.
Trevor B33, what did you find?
I done mine mate.
A big thread On here and also mk5 gti.com most reporting the same things, improved mpg, no lights and slight more turbo noise :)
http://www.briskoda.net/forums/topic/197778-pre-cat-removed/
