Rear ABS sensor
Need to sort rear abs sensor out as light has come on and fault recorded is rear abs sensor,where are the sensors located and is it an easy job model is a 1.9 tdi 130.
yes is easy to replace...take the wheel out and on the back of the hub you'll see the bolt,undo and pop it out
Thanks will get it sorted at the weekend as mot coming up.
Comes up as rear left which is that is it nearside?? also getting a flashing/beeping warning light as i drive thought it was service but thats been cleared so could it be related to the ABS???
Edited by gaz130
