1.8T fuel pump compatible with other VAG engines?
I'm not sure but is the fuel pump from 1.8T compatible from other VAG engines or Octy's engines like 1.6 or 1.4 16V??,I'm not sure.
I found a fuel pump from 1.4 Fabia,looks exactly the same,I bet has the same 3 bar.I guess will fit,would it?
I don't know for sure but VAG do have a tendency to use parts across a lot of their cars
The 4x4 pump is different but AFAIUI the rest are pretty much the same
4X4 has 2 pumps,and I bet one of them is the same
The 4x4 has a different main pump with 2 outputs , the second pump is powered by that pumps extra output , not electric. It keeps the fuel in the main pick up side of the tank.I know because I had problems with mine struggling to keep enough pressure.
