Few quick questions
Hi all, few quick ones...
Just ordered prosports, even though I plan to, will I need spacers to clear the coil? Can I drive it until the spacers arrive?
Are these also the right drop links? http://www.ebay.co.uk/itm/350710659524?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
because I have been looking at coilover fitting threads and they don't look quite right. Also, spotted these, will they do the job, or is that what is already on there? http://www.vwspares.co.uk/product_info.php?products_id=255
when using spacers, what bolts will I need
and finally, does anyone have a picture of the milotec rear diffuser on a black car?
Your bolts should be longer by whatever the width of the spacer is, eg 8mm spacer- bolts need to be 8mm longer
Isn't there also a different bases to the head you need as well depending if it is an OEM wheel or after market ??
Also, what length are the current bolts?
Cann't remember OE length of top of head
There are a few different designs of lug nuts/bolts
So if you've got a wheel which requires a tuner spline drive bolt, you'd need to find longer bolts of that type
Typically, spacers would come with conical tapered bolts for VAG cars
