rear parking sensors and reversing lights have died
odd one this. my car was fine all of a sudden i jump in go to reverse no beep's and i cant see anything behind me. is there a fuse for this?
thanks
checked the fuse its not that anyone?
It might be the reverse switch on the gearbox
for both items to have failed i would be looking at reverse switch on gearbox
okie kokie cheers both. it randomly worked once or twice today so loose connection/broken wire is what i was thinking
Happened to me, was the wiring at the reverse light switch connector. Just need to remove airbox gubbins and you'll prob see a broken wire (water gets at it easily there I think). And even if it turns out to be the switch itself, they are cheap. I bought one thinking it was the switch and it was only £15, but when I went to change it, I found the broken wire.
  • 11 years later...
Did you get to the bottom of this issue?
In 11 years the car has probably rotted away, died a death or long since been sold on. Is the forumite even around?
Edit: to answer my own question, OP not seen since 2015.
Edited by Me-109
