Fuse box by feet
Ok.... I may at somepoint try and do my gauge connection :D
Slowly doing them bit by bit to make it easier for dave
So far they are in place and all wires are in drivers foot well
Any help on which is
Permi live
Ign
And where i can get an earth there
Or anyone i shouldnt use
Illum i'll get from light switch
Appreciated
There are some marked unswitched red terminals (permanent) and a large yellow unswitched terminals marked under there. Should be able to earth there to a chassis bolt if need be, but you're better off keeping earth runs as short as possible, as I'm sure you well know.
Yeah its only the 3 gauges with hair wires lol
1.0mm cable ive made the triple loom from lol
Oooooo so thick
I'll have a nosey
iirc the switched live is the X75 terminal on the back of the board, normally two yellow and black wires attached
Cool, then just hunt for the multimeter for the permi then
And a poxy earth lol
Here you go:
Now thats very handy and awesome
Dont use aye :D glad u marked that
Just need some rings or forks now
Dont supose anyone know if those r m6 bolts n nuts by anychance
Thought id ask before i go peeking :)
Cant remember the size but they were certainly smaller than M8, so M6 stands a chance, IIRC I used a 10mm socket to remove the nut.
I think the ring or forks r like 6.4 or sumin so should be ok :)
what he said!
great pic by gizmo68 too!
Am i right guessing the ring connectors would be better than forks ?
Rings are more secure, but a pain in the butt if you need connect/disconnect the wire with any regularity
What would u use mate ?
I was just thinking itbwould stop them from coming out and touching something bad ?
I'd personally use a ring, then put a inline fuse holder in the wire
Protection plus ability to easily disconnect power without tools
Cool, i'll get some rings then mate :)
cheers
Ive made a fused loom ready
Ign, live and illum :)
lol im sure its been nearly a year to get these in
