Will VW MK5 Golf Match alloys work as Octavia VRS Winters
Can anyone tell me if Mk5 VW Golf Match 15" alloys will fit my 62 plate Octavia VRS. I want some winter wheels for next year and have seen 4 x with good tyres for sale at £180. Will they do the job. Thanks
Edited by AlScott
Think you need 16" rims to go oveer the 312mm brake setup.
+1 expect the front discs and calipers will be too big. 16's from anything MK5 Golf based should do the trick.
Thanks for your reply
I also suspect golf will be 5x100 and octy could well be 5x112
As above you need 16" min to fit over calipers
MK4 Golf use 5x100, but the MK5 onwards uses 5x112, you need 16” minimum though as others have said.
