felicia lowering
fitted some mk2/3 golf rear coilovers to the felicia today and the back is still same height as standard even tho coilovers are wound right down. what could this be??
Not too sure what your problem could be, when i had mine wound all the way down it was pretty low but very harsh. Have you lowered the front?
What wheel/tyre combo you using?
Edited by nu99et18
With mine set at the bottom the tyre is touching the wheel arch..
I should have thought youve assembled them wrong surely? You're not hitting the bump stops are you?
Ive got mk2 golf coilovers but told there same as mk3 but there just one spring they dont have a helper. Getting shorter springs made for the coilovers so be able to go low
Not lowered the front yet and still searching for wheels
What coilovers have you got exaxtly? Because some will lowet -120mm yet some only lower like -60mm so if you have some that only lower -60 this could be the problem
Just massive springs in coilovers going to shorten them mk3 golf rears and mk1 focus fronts
  • 7 months later...
Did not want to make a new topic but i have a question, do golf 3 or some other makes lowering springs  fit felicia? I can not find felicias lowering springs for a reasonable price here in estonia, but golf 3 lowering springs are cheap.
