fabia '3' 1.4tdi question 2009/09
Hi guys couple of questions. Firstly am I right in thinking the above engine doesnt have a DPF? Also does the aux output only work with the skoda head unit or would it still work if I were to ever change it?
Thanks In advance
Watcha Adrjgberg, welcome and hope you like your car. I have one as well but the level 2 trim. Firstly, I'm pretty sure you do not have a dpf on your '09'. The Greenline does but if you have the standard motor, then no dpf, and I feel fairly sure of that. You 'aux' socket should work with any head unit that has that facility to plug the socket lead into it. It's a standard jack if I remember correctly. But you may want to check that before you buy another with your dealer. Is there something wrong with your head unit?
Good stuff thank you! Nothing wrong with head unit but I have a very good sony head unit thats been in my spare room for an age, wouldnt mind fitting it
