Vrs heater matrix HELP
Hi Folks
Hope someone can help .
Has anyone replaced heater matrix and if so could you please give me any info/tips as how you did it.
Had a wee look at Haynes and it states that it can be removed in situ but also states most of the dash needs to come out .
Any help would be greatly appreciated
Regards Whoosh
Anybody
Pleeeeeees
I'd of thought the dash does mate. Every heater matrix I've done the dash has come out so I'd be surprised if this is any different
Looks very much like it
Regards Whoosh
the glove box and centre console come out pretty quickly / easily if thats all that needs removing
As mentioned you need to remove the glove box and centre dash, so stereo, asr switch and heated switch have to come out
I'm taking the heater switch out in the morning so will let you know how easy it is :)
Edited by DanHam
Thanks for your help
Regards Whoosh
i found the asr and heated window switches hardest bits to remove lol
How do you remove them actually?
no idea how you are meant to remove them there are 2 steel spring clips behind them but as they are side by side i couldnt get to the centre 2 .... i wasnt very successful lol
I'll show you tomorrow Dan if you get stuck :)
Ok mate I'll do my very best and take all the switches out etc :)
For removing the asr switches etc i just removed the radio first and pushed them out from behind, seemed to work ok.
Exactly as you said lol
Just removed all my lower dash last night. Comes out easy enough.
Follow the guide as dark hero posted, then the links through that. Very easy to do tbh, probably around an hours work in total. The fiddlesticks ones are the 4 screws underneath the heater panel, kind of above the ash tray.
You will need a small Torx screw driver or even a wratchet connection as there isn't enough room in some cases to get a screw driver in :)
