4x4 rear wheel bearing torque wrench setting?
hi, does anyone know the correct torque wrench spec for the rear wheel bearing on a octavia 2001 4x4? the bearing is fitted on its own not like all other octavias which come complete in the hub. Cheers,Ralph.
The autodata disc i have states that the torque setting for the 4x4 octavia rear hub is the same as the front ones. this is as follows
1. Use new nut.
2. 225 nm.
3. Slacken off & rotate hub.
4. 50 nm
5. then extra 60 degrees.
Hope this helps.
cheer's will do.
