312mm brake question
Quick question just need a yes or know Awnser
If I get the 312mm calipers with discs and pads do I need the carriers or can the calipers if on the stock vrs carriers ?
Edited by j.braderz
You need the carriers as well if you are fitting them to a fabia.. On some mk4 golfs you can use the caliper on the existing carrier but they are not the same as the fabia ones, hence why there is sometimes a bit of conflicting info knocking about on this subject.
