No ABS/Traction I have fault codes
Evening all, i hope this is the right section. I bought my 04 Fabia VRS last night knowing it had ABS/Traction problems as i bought the car off my mate and had already had a look at it and scanned it. It appears that a washer jet pipe had come off and leaked water all over the ABS module.
Fault codes are...
01200 - ABS vavles supply - static, no indication on display
18057 - Powertrain data bus: missing message from ABS controller
17911 - Load signal from alternator term - Implausible signal
65535 - Control unit failure or internal control module
01316 - ABS control module - sporadic - no communication
01117 - Generator terminal DF load signal - static - implausible signal
01598 - Drive battery voltage - sporadic - signal too low
Would anyone agree that the problem lies with the ABS module and that i need to replace the module only, not the full ABS and module altogether.
Appart from the above issue i absolute love the car :rock:
As BBA Reman.
