quicky about tyre pressure
i have 205/40/17 tyres on a fabia vrs, whats the correct pressure they should be at?
If they're the standard size it should give you the pressures on a lable inside the fuel filler flap
I've used 33 psi in the front and 30 psi in the rears for the last 127k miles with good results.
there not standard cause the inside of cap shows for 15's and 16's not 17's
Perhaps you should in the fabia section as it's little more specific
In fact I'll move it for you.
Ok, not having a furby I didn't realise that. Not sure where you'll get the answer - perhaps the tyre manufacturer will be able to advise. Maybe it'll depend on things like the overall weight of the car and axle weight loadings front and rear that will determine what they are
Contact your tyre manufacturer with your axle loads and tyre size, and they will supply the correct pressures.
I just bang in 34psi on every car!
Loses a few psi after a while anyways
exactly what I do ! With every car I've had and never had any problems ...
I always use 32psi
Using 2.2 bar on those compressors at the garage - it confuses people !!
