Will these wheels fit?
Scooby wheels 5x100 which is right but are et50-does these mean they will sit out and look nice or sit in? And centre bore is 64mm so would spigot rings sort this? Cheers peeps
I know very little about tyres and wheel fitment, but I have seen this tread pop up a few times in the past.
Iirc the centre bore is to small to fit over the Skoda hubs, meaning they will have to be machined out to fit correctly.
Do a search, I'm sure loads will pop up.
Et 50 means they will sit further into the arch.
Vag centre bore is 57.1mm so you would need some form of spigot ring.
Also, iirc.. The bolt holes will be smaller too.
thealienfromuranus had Scooby speedlines on his Fabia after having them re drilled. Jay-s now owns this car :)
Yeah dont they need drilled out?
Scooby is m12 vag is m14? Iirc
Won't bother with them then. Cheers lads
