Evening all.
Discovered slight play on the front o/s wheel. I'm sure it is the bearing so has been booked in. Before I take it in -
can the bearing be tightened?
Cheers.
Lex
Evening all.
Cheers.
Lex
No. If it is the wheel bearing, either the ball bearings or races will be worn.
Not to harp on but ask them to fit a genuine VW supplied bearing if you are keeping the car for a while.
If the bearing is worn, you will hear it, have no doubts about that,
Thanks for replies.
The garage I use fit Padget parts. I willl ask though. They do use TPS if requested.
I'm sure I can hear a low rumbling sound which is why I checked for play.
Going in on monday so I'll update.
Lex
Deffo need to use genuine, others are like chewing gum compared
Pagid or Pattern? :D
Udpdate time
Turned out that the near side rear was worn so TPS parts requested. Cost an extra £50 quid so the bill came to £189.00. Would Pagid have been as good?
Lex
I would recommend a new drive shaft nut, re using them can apparantly make them loosen?
