fabia water leaks
my 2000 fabia leaks water around the bottom of each door, it looks like the door seals are not strong enough.
I also had water comming in from the engine bay which I fixed by clearing out drain holes.
is this a common problem.
Yes
The ancilleries carriers (the big aluminium plate holding the window parts on) need re sealing.
Yes
thanks for your help with this problem,
I just proved the problem into that area by pouring water down the door window so that water would run into the space between the door.
I then took the three bottom screws out, and managed to see water seeping out from the the seal at the aluminium plate.
next problem, how can i get the door cards off ?, how is the window winder held on ? ?
I had a similar problem with a mk2 golf i owned - the plastic had come away from the door.
this would appear to be a similar problem, but all doors on my fabia are affected.
thanks for your help with this problem' date='
this would appear to be a similar problem, but all doors on my fabia are affected.[/quote']
i've just managed to get the door card off - window winder has a very strange clip to hold it in - the screww on my golf was far easier
anyway now for some mastic sealer.
