Gauges
Hi all,
I'm thinking of modding the gauges in my mk1 TDI Octy does anyone no if the vrs speedo will be a direct fit .?
Is it just the speedo you want to change?
The Vrs one will fit as its only a plastic sheet that you need to change but with the different rev range etc its not really worth it. You could probably get the insert from a golf/ bora tdi which would be a better choice
Or you might be able to use a Fabia Vrs one like this??
Would need a small cutout for the 2nd clock adjuster
Ya nice 1 looks Gud cheers for dat nd ya it's just the speedo
Hi man, I have one off a diesel Leon Cupra if you want, same rev range and will fit. You can use the plasic method as used above, that's what i did with my old toledo. They are white gauges
Sorry to jump in but..............
do the cupra TDi gauge's ( plastic dial cover in white ) fit right on the TDi octavia dial's ( mine is a mk1 pre-facelift 1999 GLX 90 bhp ) ?
Thanks Marko
* Speedo and the rev counter *
Yes they'll fit, I'm almost certain there's a thread here with the cupra gauges in an octavia
Thanks Mate, i just need to find some for cheep cash now lol
