Fitting my ICE in my Furby
Hi,
I've decided to finally stick my kit in my furby as I'm a bit bored of having no bass in the car. I've just been out in the car and started feeding the RCA's and remote cable down the drivers side of the car from the boot but can't seem to find a gap to pass the cables through to the back of the HU. I've had a look on the forums but can't seem to find a guide with working pics that shows this stage. I've found the power cable guide but I'm gonna do that next. Any ideas on where to feed the cables through, as it looks very closed up behind the HU and from under the steering wheel. All my previous cars have had obvious gaps which you can see straight through but the furby is proving more difficult. Anyone in Milton Keynes wanna give me a hand? :thumbup:
Cheers for your help
I found the best way was to feed the cable through the dashboard with the radio out. With the radio out slide the cables down the drivers side. They should then pop out to the left of the pedals.
Hope this helps.
All my cabling goes down the left hand side, the power is right up against the sill the RCAs, remote(s), and a few others go against the centre console. My speaker cables for the left door also go down the left next to the centre console. Right speaker cables go down the right hand side of car.
I found that with the glove box out you are able to run them behind a braket for an airvent along the underside of somepart of the aircon and then under the carpet at the top of the footwell. My remote cable goes down the centre console and out into the ashtray, I have a switch panel in there, four remotes wires then go down the centre of the console and under the passenger seat through an eyelet in the crossbeam and off to the boot.
Cheers I got all the cabling done, just need to cut up some wood for the false floor and I'm done for now, then comes the carpeting. I'll post some pics when I've finished.
Next on my list is to put in my components but I'm useless at cutting wood has anyone got a spare set by any chance or out of the kindness of their heart want to make me some :D
Cant really help, but it be nice to see the finsihed thing, being in MK :thumbup::D
When I've finished I'll drop you a pm. It won't be pretty but it should work which is the most important thing.
