Forge Alloy Boost Pipe Adapter
do you know if this will fit the lower boost pipe off a kkk turbo?
very interested if it does
Edited by simon-g
Which do you mean mate? Will it join to the alloy pipe that runs between the intercooler and turbo silicones? I can find out as I have an OEM turbo outlet pipe at home I can compare the connector size.
It won't fit the actual turbo outlet though, thats a much thinner connector than a boost pipe one.
.im on about the fitting into the actual turbo itself...
I have a fmic ..and all my pipework is alloy or silicone..so ive cut the adapter off the old boost hose coming out of the turbo,and put my own 51-57mm silicone hose on to mate up to my 57mm ppipework.
so its just that adapter which is the only old standard part I have left.
Ah no, this wont fit then Simon mate.
oh bugger..ok matey..
thanks anyway
Nobody want it? Looks destined for the parts pile in the corner of my garage!
£15 delivered!!
