I got bored and found a sheet of vinyl!
Good work there m8, looks awesome
Sent from my GT-I9300 using Tapatalk 2
Looks very well done
There's a tiny join in the bottom if I'm being picky but quite pleased!
At least it matches the mirrors and wheels
well smart...
I like that,top job :)
I nearly did mine in a grey that looks awesome! :)
Any more pics from a bit further back? Is it easy to do? I've never vinyled any parts before.
Ill try and get some I've also done the b pillars!
It's not hard but its fidley to get on right
I cut rough template to large laid it over and started stretching it out using hair dryer!
B pillars is next on my list! Any tips on that?
That was quite easy, open said door cut a strip around 2inches bigger than the pillar all round
Stick it down on the top edge, put tight and smooth down as you go then trim off once stuck down behind the doors use the body line to trim along the top and bottom of b pillars
