fabia 1.4 16v.. 51 plate
hi all,
problems with wife car, power steering is very intermitent and steering light comes up on dash.
have gone through fault codes and this is what it reads, can anyone point me in the right direction to fix this.
dont know weather to go with ; new battery, steering sensor, steering pump please help ?????
thanks
keith
Saturday,11,May,2013,15:23:17:36838
VCDS Version: Release
Data version: 20101206
Chassis Type: 6Y - Skoda Fabia I
Scan: 01 02 03 08 09 15 17 19 25 37 44 46 55 56 76
VIN: TMBPC16Y623326234 Mileage: 113960km/70811miles
Address 01: Engine Labels: 036-906-034-APE.lbl
Part No: 036 906 034 AE
Component: MARELLI 4LV 3778
Coding: 00023
Shop #: WSC 13765
VCID: 55AA9DD08587
TMBPC16Y623326234 SKZ7Z0A1034171
2 Faults Found:
17559 - Long Term Fuel Trim Additive Air; Bank 1; Range 1: System too Lean
P1151 - 35-10 - - - Intermittent
17953 - Throttle Valve Controller: Malfunction
P1545 - 35-10 - - - Intermittent
Readiness: 0000 0000
Address 02: Auto Trans Labels: 001-927-731.lbl
Part No: 001 927 731 H
Component: AG4 Getriebe 001 2981
VCID: 1628DADC5801
1 Fault Found:
01314 - Engine Control Module
49-10 - No Communications - Intermittent
Address 09: Cent. Elect. Labels: 6Qx-937-049-B.lbl
Part No: 6Q0 937 049 B
Component: BORDNETZ-SG. 1S31
Coding: 25626
Shop #: WSC 13765
VCID: 3972316009DF
1 Fault Found:
01598 - Drive Battery Voltage
07-10 - Signal too Low - Intermittent
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 1C0 909 601 C
Component: 01 AIRBAG VW51 01
Coding: 12337
Shop #: WSC 13765
VCID: 2044FC048A45
1 Fault Found:
00532 - Supply Voltage B+
Address 17: Instruments Labels: 6Yx-9xx-xxx-17.lbl
Part No: 6Y2 919 860 C
Component: KOMBIINSTRUMENT VDO V09
Coding: 16441
Shop #: WSC 23008
VCID: 458A4D907527
No fault code found.
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway K<->CAN 1S31
Coding: 00013
Shop #: WSC 13765
VCID: F0E44C449A25
Address 44: Steering Assist Labels: 6Q0-423-156.lbl
Part No: 6R0 423 156 B
Component: LenkhilfeTRW V277
Coding: 10110
Shop #: WSC 00000
VCID: 2F660F38C79B
1 Fault Found:
01290 - Reference Voltage; Steering Assist
29-00 - Short to Ground
End ---------------------------------------------------------------------
