Coolant Temp Sensor Changed, Worth Bleeding Air out?
As the topic says really. Lost a small amount of coolant. topped it back up and level is fine. Worth bleeding though?
No need to.
If you only lost a small amount then just topping it up to required level will be fine. Keep an eye out to make sure you are not losing any coolant in the coming days. if you are then it's possible that the connection didn't reseat properly or rubber washer is twisted.
Thanks mate. Didn't think anyone was going to reply lol
How do you bleed the coolant?
