AT WITS END
In need of some help guys , when I'm pulling up thro the gears (not thrashing just normal ) the front end seems to squirt n twist all over the place pulling one side to the other , tracking has been done , has new wish bones so bushes are good and tracking rod ends fine , it just as tho the front end won't setting
Edited by mick71
Alex_e3 had this same issue. He'd changed a ruck of parts like you too. Cant say if hes solved it since, he might see the thread :)
Are you wheels balanced / not buckled?
Wheels straight and balanced , its as tho car is trying to straighten itself
Have you got standard wheels? When I put non standard wheels on one of my cars, the offset was not identical to original (close though) and they were slightly wider than original. These combined made the car undrivable. It tramlined, steered itself and veered off in differant directions under braking.
Standard wise wheels/tyres now on and it drives like new :)
No play in the rack or anything?
CV joint?
Standard wheels , everything tight underneath , seems like it has mind of its own anytime I go near throttle
How low is it? On it's arse? Try winding up a bit, seen a number of fabias that are very low get really wandery, not quite sure why. Something must get thrown out.
It is low like , but it handled great till after new wishbones were put on , but it is the correct ones
How are the engine mounts seen other cars have probs like your and it was knackerd engine mounts causing the fault just somthing to cheak if u havnt all ready
Have you had 4 wheel alignment or just tracking??
It's going in later to get all checked underneath (including subframe bushes ) and 4 wheel alignment. Hopefully get to bottom of this , scared to take kids n wife in car
