multiple codes
Hi I've got a octavia estate 1.9 tdi 2006 01393 sensor for level control. 00257 abs inlet valve front left. 00290 abs wheel speed sensor rear left sporadic. 00287 abs wheel speed sensor rear right sporadic and 00229 refrigerant pressure sporadic 002 lower limit exceeded thankyou for any replys
Level control doesn't seem to apply unless you have plasma discharge lights, since otherwise Octy's don't have auto-levelling anything.
For the ABS faults, if the system works and isn't throwing the "ABS faulty" idiot light I'd not be too worried.
For the refridgerant message, if the car has aircon or climate control, treat it to a regas. I don't normally recommend KwikFit, but they'll do this right for a decent price or give you a fault diagnosis you can take to a specialist automotive aircon place for free.
IM currently doing a mechanic course and took my car into college and tried to regas it there but it wouldn't work I've just seen on here it may be an aircon pressure switch has gone I've not had any suspension work done at all
