Hi
My Fabia is losing anti freeze but i cant see a trace of a leak , could it be that the cylinder head gasket needs replacing.
The car has done 53000 miles.
Have you checked your oil to see if its milky ?
Yes i forgot to mention the oil is normal.
First check the corners of the radiator, look for white corrosion marks. Then do the same on the pipe joins, especially the one near the bulk head on the p/s. after that have the coolant tested for exhaust gas.
Thanks ill do that.
Tomorrow morning before you drive it, open the coolant tank is pressurised.
