Which part number? Inlet Manifold Flap - PLEASE HELP!
Hello everyone,
I really needs some help here. I have a Skoda Octavia II 2005 2.0l TDI PD yesterday on the way back home I got the "Emissions Workshop" message scanned the car and got the the famous:
19558 - Motor for Intake Manifold Flap (V157)
P3102 - 000 - No Signal
Freeze Frame:
RPM: 798 /min
Torque: 34.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 13.91 V
Bin. Bits: 00101000
Torque: 160.0 Nm
Torque: 0.0 Nm
19557 - Motor for Intake Manifold Flap (V157)
P3101 - 000 - Open or Short to Ground
Freeze Frame:
RPM: 798 /min
Torque: 32.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 13.98 V
Bin. Bits: 00101000
Torque: 160.0 Nm
Torque: 0.0 Nm
17075 - Fan 1 Control Circuit
P0691 - 000 - Short to GND
Freeze Frame:
RPM: 798 /min
Torque: 34.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 13.98 V
Bin. Bits: 00101000
Temperature: 87.3°C
Duty Cycle: 9.6 %
Now the original part number is 038128063G I have rung TPS and they told the part number has changed to 038128063L however I have had a look on carparts4less.co.uk and they have the 038128063M which they say is suitable for my car also other websites confirm this. Has anyone got ETKA so that they have a look which part number is suitable for my Octy?
Thanks for helping out I really appreciate it
Ok so I have managed to sort this out. It seems strange that Skoda parts dept didn't know which part was suppose to be the correct one. The guy that I spoke to had to confirm it and call me back. Eurocarparts was correct as well they can't look up VAG parts but they can look up manufactures parts and in this case it's Pierburg.
I have spoken to a guy from Poland and he pointed me in the right direction. What you need to do is to follow these steps:
Go to http://www.ms-motor-...ndex.asp?cls=02
On the left hand side menu click on Products and Catalogues
Then click on Electronic Catalogue
Now you will be prompted with a simple CAPTCHA and hit continue
After that click on Reference Number
Then you can type your original part number
In my case this was 038128063G
Once the part is found there is a INFO link on the left hand side click on it and this will open up a PDF file with the info on this part.
I have tried all the parts ending L and M and all of these point out to the same manufactures part which is as Eurocarparts confirmed is:
7.14393.26.0
So there you go part has been swapped tonight and after taking a ride in the car and leaving the engine off for about 15 minutes switching it back on again the engine light has gone off on it's own.
https://onlineshop.m...0095_en_web.pdf
Dealer quoted me £358 after tax for this baby so that's a £158 saving. Thank you very much!
Hope this helps!
PS. The guy from Skoda said I didn't have an Intake Manifold Flap because I drive a diesel ....bloody shambles!
Edited by arthurd123
