EGR valve?
What'll it take to get a piccie of my new turbo on the engine. ;) Did notice the pipes go out a different direction to the vRS turbo, so hoping the FMIC pipework is designed to match. :)
EGR? :rofl:
Have you got a hybrid for the Octavia platform then?
Well, its a VNT17 for sure, but I did notice a garrett label on the controller. If the FMIC pipework doesn't match it, then.
The original turbo kind of has a pipe coming out toward the driver's side, then going out to the right & down. The new one has the same position inlet, but the outlet goes upward. :) Might check with Allard that they got it right. As long as the FMIC is designed to work with THIS turbo, then all's OK I guess? :confused:
The i/c pipe on the turbo (outlet) is 90 degrees different on the Fabia to the Golf type one as that points directly at the chassis leg if fitted (I know I did it myself).
Yeah, the old outlet did point at the chassis leg, but this one is proudly vertically erect... oo-er. Weird thing is I vaguely remember the Allard FMIC having a pipe going vertically off it and was wondering if this was to match up with the vertically pointing turbo? :confused:
It could well be that then.
