Needed instructions - fit DAB antenna cable into the dashboard
Hello,
can you please indicate some instructions how to fit the cable Antenna from HU to outside, towards the right side of the passenger, going inside the dashboard ?
I have a Skoda II and I would like to mount the antenna DAB onto the inside windscreen at passanger car.
Many thanks
Daniel
I've done this for my RCD 310 DAB headunit.
To get the best access you'll need to remove the glovebox, which is pretty straight forward, just 4 or 5 T20 (or maybe T25) torx screws, including one that you have to access by removing the small side panel that you can only see when you open the passenger door (the one that feeds the airflow through to the door).
Removing the trim panel on the passenger side A pillar is also easy, you just have to give it a good tug (unless you have curtain airbags, which makes it slightly more tricky).
You'll also want to remove the top centre vent/storage box (with the hazard switch in) to give you much better access to the back of the headunit area.
Applying the antenna film to the window itself can be a bit awkward, and I'd strongly recommend you test-fit it a couple of times before removing the backing!
I've got a few pics somewhere from when I did mine, I'll see if I can find them...
Here:
^^^^^ :thumbup: What Chris said :)
Hi Chris,
thanks a lot, I will give it a try. Promise to put a picture when the job is done.
Daniel
No probs, good luck.
