Rear wheels tyre wear.
Both my rear tyres are showing wear on the outside edges,similar to the fronts.
I could understand it if it was 4WD and I Hooned it around corners.
The tyre pressures are correct and I rarely carry any rear loads.
Are Yetis set up with rear wheel toe-in?
do any other 2WD owners have similar?
My 2WD with 1600miles on the clock is showing no signs of any wear.
Fred
Getting good mileage from my Dunlop SP Sport 01's. Rears even wear and about 5.5 - 6 mm
remaining after 26000 miles.
Front's however needing replacement soon at 2.5 - 3 mm as I recall, again even wear.
No abnormal wear on mine after 26000 miles.
Swapped front to back at around 16000.
All 4 down to between 3 - 4 mm
They're the Dunlops by the way.
