Advice on removing A pillar trim?
Hello all...
Any advice on removing the right side A pillar trim, successfully without snapping and breaking :rolleyes:
Cheers :)
Its tricky, if you just want to run the wire across mate, pull down the door seal and run it up the gap behind.
The trim just pulls off, but usually the metal clips stay behind.
I did consider running it up the door seal...
Think I'll be going down this route, have to figure out a way of running the wire to the middle of the headliner, could do with some nylon draw cord.
Cheers :thumbup:
run cable up seal thats what i done
Think I'll be going down this route' date=' have to figure out a way of running the wire to the middle of the headliner, could do with some nylon draw cord.
Cheers :thumbup:[/quote']
Gently tuck it up the front of the headlining next to the windscreen. You'll find you can pull the edge down.
