pd 130 engine differences?
are there differences in components on the different engine coded engines? all are pd 130 engines so power should be the same but are there any benefits of any with a particular code?
No real benefit worth worrying about
so no engine has anything better then any other? my fabia has a blt engine I don't know if this is the most common or if there is anything good about this engine or bad?
BLT put out slightly more power (10/15bhp) standard, egr valve is a bit different but nothing apart from that as far as I know.
No
Blt uses a different egr setup (has a cooler) to meet euro 4 emissions, asz doesnt have this as it was only euro 3 emissions then!
There is no benefit to either engine, they both tune up exactly the same
I want to get a bit more power out of it as iv been used to driving my saab 1.9 tid for the last 3 years and the fabia is a fair bit slower so want to boost it a bit. I aaume a remap will get to around 160bhp? and an extra 30lbft? I was expecting it to be quicker then my saab being smaller but was very much let down so need some extra
Yes go to a decent mapper
Any one of the sponsors on here will give you a safe map, well maybe not one.... Begins with awe and ends in some.
Should get 165-170bhp and around 300lb/ft
