vRS TFSI 2006 Gearbox
Hi Everyone!
Which gearbox does the 2.0 TFSi VRS use?
Thanks for any info,
Stu.
02Q
Thank-you Harry.
Is it the same box which is used by the diesel vRS?
Trying to find out the max power and torque they can take.
Thank-you Harry.
Yeh. Same box for the diesel. They can take a fair bit of power.
Are you sure?
Usually diesels have a long ratio box.
Both the petrol and diesel versions use the 02Q box
Yep you're right, O2QH.
Good to know we've got a wide selection when ours go pop ;)
Edit:
I think I was right before, the ratios appear to be different. Even though they are both described O2J the gearbox code (kxz in the diesel case) are different along with the ratios.
http://seat.workshop-manuals.com/leon-mk2/index.php?id=939
