Fabia door lock motor repair?
Hi there, I've recently picked up a 2002 1.4 16v estate and the passenger side eletric window regulator cable snapped so I bought a kit to repair and have made most of the rookie mistakes....snapped the wiring clip which plugs into the motor and seem to have broken the plastic clip where the locking rod fixes onto, doh!
Does anyone know the part number for the plastic clip on the motor? (assuming this can be replaced rather than the whole unit?) Can it be purchased from anywhere other than a main dealer?
Also, what are the size of the large torx bolts which hold the motor to the door? And is it just a case of removing these two to remove the motor? (everything else has been disconnected)...
I've got engine woes too (EGR valve, excessive flow - intake air system leak detected) but I'll try to fight them another day!
Any help is greatly appreciated!
Thanks,
Rog
Edited by rogvespa
