from 901 kg front axle load ? advice please..........
hi folks got me h+r springs delivered today theres a part number on the box 29073-2 and also states,from 901 kg front axle load. could someone educate me about these axle weights .just want to double check that they are the correct springs .ive a 2011 fabia hatch 1.2 tsi (85). thanks folks in advance.. :think:
see p197-198 in your vehicle operator manual.
thanks but i cant see just the weight for front axle.!!!!
the unladen weight should be listed in the manual p204 (1116kg) and short of actually putting the car on a weigh bridge. you can probably assume your weight distribution to be split around 60/40 font/rear. Your weight plate on the inside of your driver door shut should tell you the max permissible axle weight (for a fab vRS estate its 920kg front 810 rear, 1713 total) i suspect yours will probably be the same if not very close.
Edited by Wibb
