amp wiring
hi im going to be wiring my amp and sub in tomorrow is dose anyone know were the best place to put the power cable through thanks
If you take the glove box out you'll see a suitable grommet in the bulkhead you can use, then run the cables down the passenger side under the trim panel.
thank you will give it a try
As said, you don't need to remove the glovebox though I you're lazy like me its doable
i took the glovebox off but cant really see anywhere my ac unit in the way
It's under the carpet mate
Whereabouts in the west mids are you?
This was covered a couple of weeks ago, if you go from under bonnet where aircon pipes go in between them and inner wing there is a big grommet.
If you lift out the relay box from bulkhead its quiet easy to get to, i have a photo somewhere when am not on my phone
i am in oldbury Decapodian
I'm not *too* far away in Bromsgrove. I can always give you a hand if needed.
Thinking about it, I seem to remember the grommet I used was underneath the pollen filter, and to get at it from the engine side you need to remove the plastic trim panel under the windscreen. It was ten years ago when I did mine though, so my memory may be hazy.
This is where my amp cables run through bulkhead
Its just behind black trunking where it runs up rear of bulkhead, there is a little relay box attached to bulkhead, lift it out and you will see it behind it, just pull firewall sound proofer to side and its there, big massive grommit
