1995 Felicia SPI - Breaking
Hi there,
I need an engine ecu for my x reg felicia 1.3 - over revving, eating petrol and occasionally troublesome to start though not for first journey of day, nor if left for 30 mins plus after stopping.
Was informed that numbers (below in bold) need to match exactly even with re-programming - have tried one with a couple of differing digits and even after re-programming car no longer starts.
Identifiers on my ecu are; Siemens Czech Rep
                                          5WP4327 05
                                          047 906 030M
                                          (40HP or 40KW)
                                          (EF SJ8 025121 F024 187)
Is yours available and if so does it match? Fingers crossed.
My mechanic tells me that it would be even better if I could get the linked coolant temp. sensor also and the last 6 digits of donor chassis number match mine (...331617).
Would be grateful if you can help and keep my felicia on the road.
Yours in anticipation, Don.
Thanks in anticipation,
Regards, Don.
I will go and check but I think it will be different as X registered cars are MPI and this is an SPI.
As I suspected, different.
BOSCH
4410.4046.028.6
Hi,
Thanks for checking for me. Will continue the search.
Regards, Don.
Good luck!
Sent from my GT-I9300 using Tapatalk 2
Updated the for sale thread linked in the first post.
